going to have a good look at the weekendMr Whippy said:There are oil leaks, and leaky patches of oil.
Is it just something around the sump plug, sump sensor, leaking down the block from the head?
Loads of possibilities before I'd be worrying. What is most important is tracking it down and knowing what it is, than having some oily patches per se.
My bad,there's a small cover over the CDV it's not the skid pan.Nosa said:Why did they take the Skid Pan off ??
Not required to remove CDV
im not sure, he said it was engine oil and i would need topvr said:That cover from the CDV is only covering the CDV connection, so is it brake fluid that it is leaking then? There is no engine oil anywhere near there.
Paza3 said:Nice one ... no ramps mmm can it be done jacking her up? or bit risky
Nosa said:Paza3 said:Nice one ... no ramps mmm can it be done jacking her up? or bit risky
Way too risky, you are halfway under the car, the Jack goes I would give your chances of survival between 0 - 15%,
I use a trolly jack under the N/S rear jack point, jack car so you can slide an Axle stand under the N/S front jack point, then gently lower the car onto it, once the car is resting on it I let the jack sit still supporting up the rear. Safer and simples.![]()
Adamski said:Way hay! An ///M driver reckons that the CDV removal is good!![]()
Happy days
Edit - sorry bout the leak
Hotride said:I found removing the CDV to make a big improvement in day to day driving, have not made the car kangaroo hop while changing gears since (not that it happened often, but sometimes when you forget lol). but my daily driving style may be more aggressive than others on here.
As i said in my post its never used or drop any oil on the drive wayBMWZ4MC said:As for the oil leak, mine has never used a drop of oil no matter how hard it's driven. If you're worried, I would put an unfolded cardboard box underneath next time you park and see if any oil drips can be seen in the morning.
