Does anyone have a guide for this? I have been trying to find it on here but can't
Got you, thanks guys.maxman said:You don't need to replace it with a modified one,just clamp the flex pipe and undo the nuts either side of the valve .Remove the valve ,then connect the male and female nuts you have just undone.You should not have to bleed the clutch doing this way.
