mine was shortened either, but if the valve itself is removed rather than modified and replaced... it'll end up being shorterAlanJ said:gannet said:.......... removal shortens the clutch line by about an inch, but there should be enough slack to take it. You may have to bleed the system slightly afterwards to eliminate the small amount of air that could be introduced.
Mine was a one for one Zekhausen replacement and caused no shortening at all![]()
