Hi there
Following heavy rain last night I have found the amp situated in the boot of my 2004 z4 2.5 is sitting in water. The amp looks goosed and is no longer working. Part of the circuit board is corroded.
I am sending it away for repair next week but very much doubt it can be fitted. Bearing in mind the £900 odd replacement cost can anybody suggest specifics of other cheaper options?
The current amp is 65126936952 Carver DSP.
Used ones seem very had to find
If this problem has not already effected your car now might be a good time to double check 1. The seal around centre brake light, 2. That there is no corrosion on the bottom of your amp. I'm wondering if drilling a small drain hole would at least stop water gathering and getting up to the height of the amp.
Anyway any ideas much appreciated
Marcus
Marcus
