Car will not lock
Lock my z4 by remote 15 minutes later the Windows go down the locks undo some times the alarm goes off and the internal light stays on . Anyone had this
Where is the key when this happens?
Assuming not in you pocket then I would think the GM5 module would be a good place to start.
Try checking the battery, many electrical gremlins come out to play when batteries get tired. Leave it for a couple of hours and measure the voltage across the terminals.
Anything less than 12.3 / 12.25 V and I'd be considering a change, definitely if you've got less than 12.1 V. Also worth checking the alternator afterwards - start up and measure again, you're looking for 13.2 - 14.4 V. If you've got less than that the alternator could be the cause of the low battery.
