Can you use voice commands with it ?It is controlled via the iDrive controller not touch screen and works very well.
If you say a decent MMI box such as Mr 12 Volt then if you’ve enabled Siri then yes no problem..Can you use voice commands with it ?
Thanks for the infoIf you say a decent MMI box such as Mr 12 Volt then if you’ve enabled Siri then yes no problem..
