You can shim the struts to give you up to 2ยบ negative on the front, but the preferred way is to remove the guide pin and put proper adjustable suspension with camber plates on.
You can also get adjustable camber plates - http://www.turnermotorsport.com/html/subcategory_detail.asp?modelcode=Z4&subcat_id=64
