Can of Holts or a waste of time?
matthurley
 Cardiff
I'm in the process of switching to 18inch non run flats
So my question is: should i join a recovery organisation AND get a can of Holts OR is Holts a waste of time?
If it isn't a waste of time how many mls will I need to fill an 18 inch?
Matt
Just be aware it won't be of any use without a means of inflating the tyre at roadside 8)
Better to go with a proper kit & this is about the cheapest you,l get :thumbsup:
http://www.amazon.co.uk/Slime-50033-Emergency-Repair-Compressor/dp/B00336YCO8/ref=sr_1_6?s=automotive&ie=UTF8&qid=1376669589&sr=1-6&keywords=tyre+slime
Keep meaning to get some of that slime stuff, now sitting in my Amazon basket waiting to be bought :thumbsup:
At the moment I have 1 large and 1 small can of Holts in the boot with a Michelin compressor. However I have read Holts is not that good, and horrible to clean from the rim.
Apparently tyre weld is only recommended on wheels up to 17", best just to check.
Iv had to call a recovery truck before for a flat tyre, it seems abit overkill but needs must!!
This was on a new TT with 18"s, no tyre weld was provided in the boot just an inflator.
There's a bigger tin of Holts that's ok for 18" rims.
I've got a can. Never had to use it yet, touch wood
You don't have recovery?................. Where's the brown paper bag I'm having an anxiety attack :o
Blew a can of Holts into a colleagues Audi TT and frankly I was amazed how well it inflated the tyre. Topped it up with some air from my portable compressor and hey presto she was on her way. Needed to drive about 10 miles and by all accounts she got home with no problem. Following day it was discovered there was a significant nail in the tyre. Good practice run for me because Holt's is exactly what I've got in the boot of the Z.
mr wilks said:
Just be aware it won't be of any use without a means of inflating the tyre at roadside...
Not sure that's correct.
Holts Tyre weld both seals the puncture and inflates the tyre enough for you to continue your journey at the recommended reduced speed.
It will only work on a small type puncture rather than a full blown sidewall split.
it is possible to clean the tyre of all the residue and get a proper puncture repair though some tyre fitters will tell you this is not possible and that you have to buy a new tyre from them.
A 500ml size will re-inflate an 18" wheel and for the sake of £10 you may as well throw one in the boot.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_560095_langId_-1_categoryId_165664
I have a compressor now just in case. I too thought that the Holtz would be enough on its own. But the forum gave me "the fear" so I got a compressor
I got a compressor from Ring - Its small enough to tuck away beside the battery and delivers a good volume of air - With an analogue gauge it was only £12 from the local motorist discount shop..
I would happily refund you the £10 if you let down your tyre on some remote road then film yourself re-inflating the tyre with a can of tyre weld :roll:
