Can I fit this exhaust myself?
alexman
I think I've decided on an H&S exhaust another member has offered to sell me - just back boxes (which go back to where the bolt on section is. Question is: is fitting simply a case of unbolting and removing the stock back boxes and replacing them with the new one and bolting on? (i.e. no engine diagnostics etc - common sense would suggest not but I'm asking to be safe!) If so, has anyone fitted/unfitted theirs themself?
I'd happily take it to a garage but I think I'd enjoy doing it myself if its straightforward.
Yup... no electronics, just unbolting and bolting up a couple of metal pipes. Easy enough to do on the the driveway.
I have removed exhausts before using the "Petach" method. A pneumatic drill will be my next choice of weapon if I had to do it again ;)
Petach method described here: http://www.z4-forum.com/forum/viewtopic.php?f=2&t=17719
diy job with just a socket set and jack. took me just over an hour to do one side and then 35 mins to do the other once I knew how to get to where I needed to be
