I know there's a fair few threads on camber pins and I think I've read most of them but just wanted to double check a couple of things:
1: sounds like the best method is to remove the aftermarket tower - tower brace I have fitted. Loosen the three mount nuts after removing the pin. Jack so that weight is off of the wheel, knock the top of the tyre so the strut is as far inboard as possible when looking from the tower. Tighten everything back up minus pin.
2. My main question... once the above is carried out I'm guessing that they perfectly pair up the cambers in an alignment session, and that this mod will just move the scope of adjustment deeper into the negative side of things.
3. Anyone got a recommendation on a front negative camber setting with no pins? I'm trying to dial out the understeer I'm getting so thought I'd give pin pulling a go.
Cheers for any advice
