20ducks said:Nice. Now all you need are some chromed clips (if I can ever get them finished by my plater, arrrrgh!).
GAZA62 said:No i did them on the car with a detail brush lazy i know but look OK![]()
cj10jeeper said:Mike - you take the studs out then while on axle stands kick the tyres a few times. If that fails lower then progressivly on the jack and they'll pop off. On the Jeeps I drive the problem is so bad we sometime literaly have to loosen the wheel nuts then drive 10metres !!!
ay8306 said:cj10jeeper said:Mike - you take the studs out then while on axle stands kick the tyres a few times. If that fails lower then progressivly on the jack and they'll pop off. On the Jeeps I drive the problem is so bad we sometime literaly have to loosen the wheel nuts then drive 10metres !!!
I used to have to use a 5 lb baby sledge to persuade the wheels off of my old Cougar. I found a very very light film of moly grease on the pilot diameter of the wheel can help.
Thin but robust....it is die cut out of a phenolic sheet.ay8306 said:I've been a little bit skeptical of these since In my experience, the bind is usually not the face if the hub to the wheel, but the pilot diameter to the inner diameter of the wheel. Based on your enthusiasm, I assume that you have had good results with this product? How thick are they?
czechT698 said:looks nice and fresh.... i want to do the same thing, only thing is, Black or Sterling? Is it possble to get a can of Sterling at the dealer?![]()
