So came across and watched this guy replace the pollen filter.
https://www.youtube.com/watch?v=jOtvOQwQKEI
In fact the bottom of the housing slides out board, he yanked it off, could have broken the clips.
But i was surprised by the amount of leaves and debris that fell out.
At least the large leaves should have not got passed the grille just below windshield.
So i removed my cars pollen filter and the same, all leaves fell out. I vacuumed the filter and refitted.
So i had a mooch around.
So i discovered that the black plastic trim the air intake is moulded into is open ended left and right, can be seen when bonnet open.
It looks like when the bonnet closes rubber seals are supposed to touch the bonnet, but are about several millimetres short.
So if like my car you park near trees and i am too lazy to but the cover on, the area just below windshield collect leaves, twigs, seeds, etc.
They find their way to the corners and get sucked under the bonnet an then under the black trim.
It would appear there is no seal from the air intake to the grille.
So all the leaves get sucked in.
The seal A is too short, allowing leaves to be sucked under B.
Tomorrow i may look at fitting some mesh across the air intake or the ends where it is open ended B, might be easier.
