Buying first bmw
Weeyum
 Texas
Hello. Just joined my first forum. Looking at a 2015 BMW Z4 sDrive28i Roadster 2D 75,000 miles. Sweet car. Had mechanic inspection with no problems. I only noticed small cosmetic faults.
Door handle does not fully retract. $600
Access cover wheel well missing
Some weathering rubber under hood
Upgrade from my Miata.
Any advice would be greatly appreciated
Not sure of protocol of questions here.
Welcome 🙂
No problem with asking questions.
The key things with the 2.0 are around oil changes (the more the better) and that the cam chain and followers have been replaced. Being a 2015 car is right around the time BMW changed over to the better ones.
Hopefully one of the really knowledgeable ones will be able to advise on the changeover dates.
Aside of that, the usual things apply.
The salmon relays for the roof need replacing unless documented as done, check around the roof pump for water and get rid of the runflat tyres (makes such a difference).
For the future, suspension will benefit from new shocks in the near future (75k miles means they are done).
Other than that, if the deal is right, go for it, post pictures when bought and enjoy it!
They won't handle like a Miata, but you get more space, more refinement and more rarity value 😎
The B21 Bot says....
The 2015 model year represents the post-LCI (Life Cycle Impulse) E89, which is generally the most refined iteration of the Z4.
Your 2015 sDrive28i will have the N20 2.0-liter turbocharged four-cylinder engine producing 241 horsepower. This is a solid choice combining reasonable performance with better fuel economy than the six-cylinder variants.
Engine and Drivetrain Inspection:
1. Check for timing chain stretch symptoms including cold start rattle lasting more than 5-10 seconds after startup. The N20 is susceptible to timing chain issues, particularly in higher mileage examples.
2. Inspect for oil leaks around the valve cover gasket, oil filter housing gasket, and oil pan gasket. These are common N20 failure points.
3. Verify turbocharger operation by checking for smooth boost delivery without lag or hesitation. Listen for wastegate chatter or unusual turbo noises.
4. Test the 8-speed ZF automatic transmission for smooth shifts in all gears. The ZF8HP should shift imperceptibly when functioning correctly.
5. Check coolant system thoroughly including expansion tank, water pump, and thermostat housing for leaks or stress cracks.
Electrical Systems:
1. Test all convertible top functions including raising, lowering, and emergency manual operation. Ensure proper sealing when closed.
2. Verify proper operation of the iDrive system, navigation, and Bluetooth connectivity.
3. Check condition of the battery, which should be BMW-coded Group 92 AGM specification.
4. Test all exterior lighting including adaptive headlights if equipped, and ensure proper HID/LED function.
Suspension and Steering:
1. Inspect front control arm bushings and ball joints, which commonly wear on E89s.
2. Check shock absorber mounts and springs for wear, particularly if equipped with M Sport suspension.
3. Verify proper tire wear patterns indicating correct alignment and suspension geometry.
4. Test electric power steering for proper assistance and feedback.
Interior and Body:
1. Inspect seat wear patterns, particularly driver's seat bolster and steering wheel condition.
2. Check convertible top fabric for tears, fading, or water penetration.
3. Verify proper operation of climate control including A/C compressor cycling.
4. Examine paint condition for stone chips, particularly on the nose and door edges.
Service History Verification:
1. Confirm regular oil changes using BMW LL-01 specification oil with 10,000-mile intervals maximum.
2. Verify timing chain and sprocket replacement if approaching 80,000-100,000 miles.
3. Check for software updates addressing known N20 issues including fuel pump and carbon buildup concerns.
4. Ensure proper brake fluid changes every two years and coolant system services.
The 2015 model year benefits from most early production issues being resolved, making it one of the most reliable E89 variants. Focus particularly on timing chain condition and convertible top operation, as these represent the highest potential repair costs.
Source: The Definitive BMW Z4 E89 Book — P. Bondar, 2026 | z4-forum.com
Well I purchased my first BMW. Can you suggest a manual and place to get parts. Thanks in advance for any help
Congratulations on your purchase. :thumbsup:
Hopefully someone your side of the pond will be able to help with your queries.
Welcome to the forum and congratulations on the purchase, how’s life “on the other side of the Sun”? 😁
Thanks. Things are ok here. Sun is up and bright
It was more a reference to being a “Doppelgänger” with all the writing being a mirror image.
The car looks lovely, I’m sure you will enjoy driving it whatever the weather, but Sun out and top down is the best.
