Business cd upgrade
Pilly45
 Plymouth, Devon
Has anyone managed to upgrade there sound quality using the original head unit, can't find much info any where, can't be doing with new head unit, the ones I have seen installed look pants.
I have the standard 6 speaker system
I found this
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=24956&p=348349#p348349
Seems like a lot of work, but its the wiring to the original head unit that will confuse me
Info on the head unit wiring can be found here
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=42371&p=599717
As the post you found indicates, the speaker fitment is non-standard, you need to be creative. OEM speaker data can be found here
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=41138&p=579722
You will need either speaker out to line level converter or a compatible amp, beyond that, you can do whatever you want with amps and speakers. Note that the speaker grilles in the door of your car have no speakers behind them. Apparently some cars have the wiring in place for them, but others do not.
