clang0203 said:
Thanks for the advice, I bought the car expecting to do some work myself just not as soon as this!
it was a private sale, only had MOT last week! I think I will change everything pads and discs are normally pretty simple I take it piston is not too bad either?
By piston, do you mean fitting a new one or a complete new calliper?
I recently swapped the callipers on my wife's 2.5i and it was very straightforward to do, with several tutorials on line if you need them.
I would invest in new slider pins too, as they are likely to be corroded.
Put cling-film under the reservoir cap first, to minimise brake fluid loss.
You will also find that the simplest solution to avoid twisting the flexi pipe is to hold it still and unscrew the calliper off it.
I used an Eezibleed kit to get the air out.
Getting the disc off can be a pain as the set screw that locates it tends to seize and the head rounds off. Or it shears!
An impact driver is useful, plus a soak overnight with releasing fluid may help too.
The discs I ordered came with new screws.
Just one other aside. One of my discs was seized on the hub and required a fair degree of 'percussive adjustment' to get it off.
Although I was careful what I was hitting, the original 18-y-o ABS sensor didn't like the shocks and packed up.
