bobo075 said:you are talking about the bulb for the rings ?
if ys you need BA9S bulb....
bobo075 said:I have just ordered some LED bulb (2 models to try them)... I will make a return when I will test them. I am looking for a more white an brighter light....
Scooba_Steve said:They will. But they do it by having a resistor draw the remaining current which it then has to dissipate as heat. As the LED packages are relatively small there isn't much surface area to use nor are they usually designed with cooling in mind, so tend to fail prematurely, in my experience.
Scooba_Steve said:LEDs will not pass bulb checks unless you buy 'canbus compatible' ones (essentially just a resistor that draws more current). I've never found these to be reliable and so would suggest getting a good brand LED such as Philips or Osram and having the bulb check disabled.
