Argggghhhhhhh :x
So decided with my sons assistance to take the wheels of the Zed and have a good check and clean before some summer fun. Recently had the brake fluid changed so knew the wheels had been off. All bolts on the first rim were bloody tight so when it cam to the locking bolt I was extra careful to ensure the locking bolt had engaged before I applied pressure. Fell back as the locking bolt sheared and damaged the bolt surface where the locking stud engages. Sh*t! So now I cant take any of the wheels off. Have found a specialist who has a tool designed just for this purpose so off tomorrow to get the broken bolt removed and the other 3, £10 per wheel. Fortunately I have a spare set of lock bolts. So the reason for this - yes you guessed it they used an airgun to tighten the bolts on completion of the brake fluid change. First problem I have had with my dealer in nearly 10 years. Will call in and see what they say.........
