Broken stubby
rayz4
 solihull
Came back from holiday and found my stubby was broken here's my new one.
carbon fibre. So decided to change the roundels to the carbon looky like.
what do you think.
Sent from my iPad using Tapatalk HD
Stark said:
I want to change mine but then I'd have to change the wheel centres too!! :cry:
... They're not expensive though. £20 off eBay, bit of silicone adhesive on the inside edge, job done :thumbsup:
Meant to show pic of broken stubby and also the wheel centres, so here they are
And thanks for the kind remarks
I want to change mine too - but I'm not going near my zed with a screwdriver to get the current ones off - seen other threads on how todo this and looks risky unless you know what you are doing - and I don't so I'll stay with the original look!!!!
If they are the same as any other BMW centre caps then you don't need to use a screw driver... Though a very small one, like from a craft kit would work. However, you could
1. Use something thin and plastic, like a strip cut from an old store card, or
2. Take the wheel off and poke 'em out from the back.
I did the second, and cleaned / waxed each wheel while I was at it :thumbsup:
Stark said:
Mini sucker thingy works....seen someone on here buy it from eBay
Yup, one of them too - you can use those little novelty plungers that you get for sticking on the back of ipods to stand them up. About £3 I think.
