Broken Exhaust Clamp on ///M - Help
gwatson
 Aberdeenshire
Well fitting my new rear silencers didn't quite go to plan. The clamp on the OEM centre section at one side broke when I went to tighten up the new exhaust, it was quite corroded, a common problem I believe.
Looking on realoem, BMW don't sell just the clamp, besides you'd never get it over the flange to fit it. So has anyone bought a generic clamp that's worked well as a replacement?
I'm thinking of something like this
A common but not widely reported issue until its too late on the ///M.
Happened to me when I had the Z4MC.
Problem thread...
http://www.z4-forum.com/forum/viewtopic.php?f=9&t=46076
Fix thread review...
http://www.z4-forum.com/forum/viewtopic.php?f=9&t=46812&p=676471&hilit=zero+exhausts#p676471
Used a company called Zero Exhausts near Ashford in Kent. The guy is a Zen Master when it comes to systems.
Thanks for that!
Unfortunately a little far for me to travel. But good to know there is a solution without buying a new OEM section. I'm still hoping a general clamp will do the job as it won't be easy to find someone specialised like that up this way.
gwatson said:
Thanks for that!
Yeah, sorry - just seen you're in Scotland! Def a good solution and relatively inexpensive stronger solution to clamps. Maybe call the guy at Zero and ask if he knows any other Zen Masters north of the border?
gwatson said:
Will get the Peugeot clamp and see how it goes :thumbsup:
Gulp, Peugeot and exhaust together rings constant problems. I hope the clamp is of better quality than the rest if their systems.
Sent from my Nexus 5 using Tapatalk
