Breakdown Cover & non-standard tyres
Colin_E
 North Hampshire
I've touched on this issue a couple of times in previous threads - but one issue that makes ditching runflats difficult on my E89 is that a lot of breakdown cover becomes invalid if you do so. When you delve into the small print (as you should) typically they insist on whatever the manufacturer fitted. My pan-European cover with Eversure just came up for renewal and I decided to bail because
a) Its not clear when / if my Z4 is going anywhere much AND
b) I'd like to switch to sensible tyres
So I wonder if anyone else looked at this and found a reliable annual breakdown cover that would work in (at least) France as well as UK even if non-runflat tyres were fitted?
Surely you'd be in no different a situation than us Z4M owners who have non-runflats and a 'mobility kit' that's never been used and the fluid is probably completely solid as no-one has ever checked the expiry date or replaced it at the correct interval?
If either of us have a blowout or slashed tyre, neither type of tyre will be much use.
Have you found one example of someone being refused an emergency tyre fix/swap at the roadside because non-RFT's were fitted? If it's actually happened someone would be shouting about it on a forum.
My AA covered me for a puncture in a run flat without quibble..
Even if the car has run flats it can only go 50 mile ish max so it’s not going to get you home on a 1000 mile journey.
Interestingly they offered me 3 options
Recovery home
Sell me a space saver
Take me to a garage with known size of replacement tyre.
I declined the last two…I had several space savers already..they just happened to be at home :tumbleweed:
On the trip to the garage the make they offered was a budget spec at full retail which would not match the premium rubber fitted.
So enjoyed being transported home.
Maybe I wasn't clear. The cover I just let lapse would have covered runflats precisely because that was what came with the car. It would cover the foam & pump combo that my Mercedes came with on that car (& presumably it would cover Z4Ms if that was original equipment for them) but there's an exclusion clause if you have 'less' than OE. When I took the cover out a couple of years ago I found most of the European annual policies had similar wording.
To be fair - no I haven't ......but I don't know of cases either where people in similar circumstances have had a fix either.
Hi Colin E…I noted your point.. my AA policy says the same..I was using precedent to indicate in my case no one checked..
In perspective a puncture with a non run flat tyre is a pleasant option compared to a totalled car etc ..
As we say in aviation better to ask for forgiveness rather than permission :thumbsup:
OK gotcha :thumbsup:
Maybe the complexity of the issue and prevalence of varying alternatives to a proper spare mean that in reality it might get overlooked. FWIW I could live with a surcharge if a jobsworth decided to investigate - my fear is getting stuck somewhere and being met with a 'non' & a gallic shrug :roll:
Based on many years and countless trips to France the chances of a Gallic Onion pulling the plug on an esoteric technicality I would say is Zippo-n where n is a very large integer :thumbsup:
