R.E92 said:35i-Nut said:soo Im still messing round trying to get this reset , Front brakes showing -190 with plently of meat on the pads
Replaced sensor not so long ago
I have chopped up my old front sensor twisted the wires and plugged back in still wont reset :x
Ive read the sensor must read below 5 ohms if you stand a chance of resetting , mines on 0.4 Ohms
Apart from a dedicated brake reset tool , is there any other software that will reset it ?
Tried my OBD reader , Torque app etc
I did buy some INPA and NICExpert software on Ebay but its useless , E89 not listed
Will the Carly Android app reset it ?
For anything related to the E89 you can just the E90 menu in INPA. The INPA menu is just a shortcut system made to make the user experience a little easier. It's the modules within INPA that are the important part and the E90 shares most of them with the E89 as they are on the same platform.
Regarding the brake reset. I think the problem you are having is down to an incorrect reset procedure. You can find plenty of info by searching the E90 forums about brake resets. You shouldn't need any special tools if done correctly, just a service reset using the hidden menus within the car itself.
Many thanks for the info , will have another go at trying a reset
I think I did actually try a reset with the sensors also disconnected but couldnt get them to play ball
