Hi, so I recently swapped out my discs and pads all round a couple of months back, due to work commitments I have not had much time to drive.
I have noticed on the near side rear that the pad(s) are only making contact with a small 5mm line around the disc.
Do you think this is caliper rebuild issue or just swap the caliper, I'm thinking maybe seized piston or slide bolts?? Any suggestions before I strip down gratefully received.
