bennyboysvuk
This is more a blog of my braking issue that I've been experiencing, but I thought I'd put it out there in case anyone else is experiencing or has experienced anything like it.
I've noticed that when I stop on a hill and just use the footbrake that when I take my foot off the brake the car remains stationary for about a second before the brakes are released and it rolls backwards. I decided to look into this and found that the dust boot on the front right brake piston isn't quite in position properly, so I assume that dirt has got onto the seal of the piston and perhaps the piston has corroded slightly, thus causing the brake stickiness.
The other issue that I'm finding is that the brake pedal has a very long travel before anything happens. I have to push the pedal what feels like more than 2 or 3 inches before any braking occurs. By comparison, my 120Ds brake pedal feel is immeasurably better and firms up after perhaps less than an inch or so of travel.
I was going to rebuild the caliper myself, but after reading into it, I dislike the messiness of the job and all the time consuming brake bleeding that goes with it and so I've booked it in with BMW specialist Lee Shannon (in Bentley), who is going to rebuild the caliper and fit a new seal and dust boot. I hope that the piston itself is unmarked, otherwise that will need replacing and apparently BMW don't sell the piston on its own, only as a whole with the caliper. Getting a second hand caliper might be an option though.
I'll update the post once the work is done and hopefully, normal, decent brake pedal feel will have returned.
