Brake Force Display Coding
philipw said:
Gents I have just programmed BFD stage 3 on my car (both centre/side lights flash). The settings I modified are below and you will find them in the LSZ module. This is made a lot easier when programming is done using NCS dummy.
BFD_SW1_STUFE2 aktiv (BFD Stage 2 activation using Deceleration Sensor)
BFD_SW2_STUFE2 nicht_aktiv (BFD Stage 2 activation using Deceleration Sensor)
BFD_ABS_STUFE2 aktiv (BFD Stage 2 activation using ABS sensor)
BFD_SW1_STUFE3 aktiv (BFD Stage 3 activation using Deceleration Sensor)
BFD_SW2_STUFE3 nicht_aktiv (BFD Stage 3 activation using Deceleration Sensor)
BFD_ABS_STUFE3 aktiv (BFD Stage 3 activation using ABS sensor)
BLST1_BLST3 aktiv (Outer tail lights blink during Stage 3 as well)
On my car these settings were already set to wert_02, modify if not.
BFD_BLINK_EINZEIT wert_02
BFD_BLINK_AUSZEIT wert_02
I'm going to do some tweaking with mine - can you confirm your fogs come on solid and only brake lights flash, or do the fogs flash too?
Not sure if the fogs come on solid now. The outside and centre lights flash as per the vid below of an M3.
[youtube]qoVFLwZfiQM[/youtube]
Any tips about how to turn all of the BFD off? It's against most race series regulations to have anything other than simple brake light illumination.
I have not tried to do this however in the LSZ module, you will find
PIN5_10_BFD- BRAKE FORCE DISPLAY WITH BRAKE LIGHTS
Set to nicht_activ
It makes sense that this would turn the stage 2, inner fog lights off. Use NCS dummy to make it easier.
