Brake fluid reset
Jasonn
Evening all
Got a bit of an issue witg the brake fluid reset - all is good but i get the annoying nag screen appearing.
Ive tried the mileage button as seen on all the you tube videos and they dont work.
Ive looked on the "how tos" section and when i press the button for the second time i getva load of gernan stuff appearing and my chassis number but no brake fluid icon (my German is limited to "achtung spitfire" and "dumbkopf").
Mine is a 2016 N20 with iDrive - am i going to have to get carista or buy a drink for my local indy?
I had to do this recently as my indy forgot to reset it, and I think the following worked (I too tried the method mentioned on the forums and couldn't get it to work).
Disclaimer: 2009 35i w/ iDrive.
1. Start car (not just the ignition)
2. Press and hold the odometer reset button until a warning triangle comes on the dash
3. Press the BC button on the stalk until the brake fluid symbol comes up
4. Press and hold the BC button and you will see a little clock symbol come up for reset, after a few seconds it will be reset.
