brake discs , pads and brake oil
hi all , looking for a bit of help . on my last mot it said on the advisory section , slight brake fluctuation .
by this i suppose they mean front discs are warping , as there is some feeling on the brake pedal , so i was looking for ideas of where to purchase new discs , pads and brake fluid .
does anyone know the exact size of the front discs , i see sizes from 286mm unto 300mm and wether they do a grooved version , not drilled as i have had experience with those in the past , or should i stick to plain ?
its not a massive feeling through the pedal but i know it'll only get worse .
hope you can help , thanks
In the Alpine register there are some details listed regarding the disks etc.
https://thealpinaregister.com/forums/viewtopic.php?t=26396
Plain discs are a solid choice for road use, with less noise and wear than grooved or drilled discs. Grooved gives a better bite but can be noisier and wear pads faster.
Disc size depends on your model; some have 286mm, others 300mm. Check via VIN or on realoem.com to be sure.
For brake fluid, standard DOT 4 is fine unless you're tracking.
