They are a doddle to fit.
Axle stands, chock wheels - safety!!
Wheel off. handbrake off
prise open caliper and off pads slightly to free them, then remove caliper with a hex wrench (2 long pins accessed from rear under protective grommet) suspend caliper out of harms way (not on the hose!!)
There may or may not be a torx set screw holding the disk on
Remove disk. You are likely to have to beat the hell out of it with a hammer as it will be corroded on
clean up and push new disk on
loosen brake fluid cap
press caliper back with a G clamp or wind back tool after removing old pads.Keep an eye on fluid level so it does not overflow the reservoir...
Fit new pads is the reverse, but keep things clean
clean disk surface with apropriate cleaner
refit caliper
pump brake pedal a few times to ensure seated
fit wheel, torque up,
repeat on other side
retighten fluid reservoir lid and check level.
Stand back - admire
Bed in pads and re-torque wheel after 10 & 100 miles
