Car is in for a service and the dealer has just told me the brake pads and discs need replacing front and rear. When this sort of replacement cost comes around I like to check whether I could be doing a bit better for my money. So I was wondering what options there are on the Alpina (basically 3.0l brake setup I think?) for discs and pads without changing the calipers. Can the Z4M disc/pad setup work without changing the calipers? Are there better non-dealer options I should pursue instead? Costing I've been given by the way for straight replacement is £344 front £318 rear fitted.
Thanks in advance
edit:- bought some time and did a bit of a search and there don't seem to be any obvious and easy switchovers. I was hoping maybe the M discs and pads would slot straight on but this doesn't seem to be the case.
Costs don't seem too bad so I guess I'll probably just bite the bullet.
Thanks in advance
