As mentioned in another thread, overhauled the brakes, discs and pads and fluid change, got to the last bleed nipple, it's that's corroded in. Won't budge, probably will break off. Need to bleed the new fluid through to that caliper and remove some air. Tried bleeding from the hose connector but that hasn't worked.
Looks like I may end needing pair of new front calipers, any recommendations? Car is Dec 2006 3.0si
