Brake bleed nipple seized
Zikim
Have just upgrade the front brakes to 325mm discs but unfortunately could not bleed system properly due to one of the rear caliper bleed nipples stuck/seized. Did not want to force it just in case it broke, does anyone know a way of loosening it?
Its not an easy one!
Heat may help but caliper would need removed.
unless you have accetylene like this guy https://www.youtube.com/watch?v=KnJ4IQVritU
Once you snap its a caliper off :cry: I take it you are using a Hex socket not multi point socket.
You could bleed the system to the caliper by slackening a union before the caliper. Messy and would not bleed the caliper body
Also
https://www.youtube.com/watch?v=gn-CvqvXguU
Good luck :thumbsup:
Easiest way is to drown it in wd40 and leave it overnight, next day get a spanner on it and don't hold back, if it snaps you've lost nothing, if it rounds off then get some mole grips on it then go buy a new bleed nipple, they cost pennies :thumbsup:
try tapping the nipple with copper hammer, while putting pressure on the spanner, if you wreck nipple just get replacement. :D
If you have access to heat ie acetylene or a small blow torch,just warm the nipple up,it should free up.
Buy a new bleed nipple with the intention of fitting it before you start again. Then wrap a small rag around the nipple and soak it with Plusgas or diesel fuel and leave it over night. Then apply a pair of mole grips to the hex of the nipple and make sure it's on tight and if possible put a metal pipe over the handles to make a long lever and apply force slowly and remove the nipple and replace.
Smartbear said:
don't use wd40 as its not a penetrating oil, it's a water dispersant
I should have been more specific, wd40 is now a brand name, i should have said:
WD-40 Specialist Fast Release Penetrant :thumbsup:
Thanks for all the replies guys. Soaked it in penetrating oil all night and then applied a bit of extra force and it came loose :thumbsup:
A bit of good advice with tight bolts. Try tightening a little before undoing. It moves the thread a little in the direction it stressed. That is very often enough to get it moving brake a rusty bond without braking the bolt. :thumbsup:
+1 :thumbsup: This trick works.... my Dad taught me this one MM
