TheRealMCoy
I've relocated the roof motor and, in the process, noticed the Bowden cable handle was not properly located in the end of the tube - it was dangling. I relocated it and then went about moving the motor. After relocation the roof would no longer open/close on the switch but the motor could be heard running.
I've narrowed the problem down to the Bowden cable. If I remove the actuator from the motor housing the roof works fine. If I attach it, the roof stops. I'm guessing it is pressing the valve but I can't see any method of adjustment?
Grateful for any hints. Thanks.
