SimonJohnson
Both front windows randomly and repeatedly drop an inch and then go back up as if the door handles were being opened and closed. This behaviour starts when I unlock the car with the remote control and continues until I've run the engine for a minute or two. Sometimes the windows also fail to drop when the door handles are pulled. I can't work out what is causing this problem. It's as if there's a control module that isn't functioning correctly. If it was just one window that had the problem I might suspect a door handle switch but it's both of them. If I just unlock the car and don't open either door the windows jump up and down for several minutes until I eventually decide that I have to do something about it and the only solution I've found is to run the engine. I've noticed that the problem is much worse on a cold morning.
Has anyone else had this problem?
