Boot\Trunk Carpet Wet
gwatson
Aberdeenshire
Guys,
Just opened the boot to discover the carpet behind the right rear light is soaken wet. Now I've very recently fitted a hardtop so could it be there is more water running of the roof and onto the boot rather than through the softop drainage system. Even still it shouldn't find it's way into the boot
So where is the water coming in? It's only the right hand side .
G
did you DIY or did you have it done? Sounds like a seal might be pinched on that side and not flowing the water properly. Have you taken the top off and looked at the seal to check for creases?
