boot badge replacement?
Theivz
Hi folks
is it possible to change the boot badge? The badge is integrated into the lock. Is it 2 pin badge?
Advice appreciated
TIA
Hi just an update I have found the answer on realoem.com gotta love that site. should have checked there first apologies. Anyway hopefully others can do this if they want to
Next step is to measure size for replacement badge :D
http://www.realoem.com/bmw/showparts.do?model=LM31&mospid=51401&btnr=41_1895&hg=41&fg=60
AFAIK its glued on, but you can remove it, carefully. Its an unusual size so if you're replacing with OEM that will be fine, but if you're going after market, you might need a bit of luck.
cheers. I get my parts from Teddy at SSDD motorsport. He has a variety of sizes so I just need to measure up when im ready to have a crack - hopefully he'll have the right size (will obviously check before i remove it lol)
Did you find the right size for the boot badge? Also does the supplier do different colours? Mines looking a bit worn and fancy changing the lot for black badges.
