Yep.. exactly what im seeing.. Thanks for replying, means alotTo me, both are pointing the same way but one appears upside down to the other, as though one is left hand side and the other right hand side.
Tried .. one number comes up as an ECU plug socket and the other is the steel its made from.. crazyYou could check the part numbers with real oem.
RealOEM.com - Select Your BMW Model
RealOEM.com BMW Parts website. This site can be used to look up BMW part numbers and approximate part prices. The Parts are grouped into diagrams and diagrams are grouped into categories and subcategorieswww.realoem.com
Whoever had it before me had repaired it.. Badly and every wire is broken or soldered to mush.. i can find the right hand side motor as theres loads on ebay.. but i cant find one of the left side.. Even the wire sockets are all beaten up.. as per piccyI’m wondering if the locking sides aren’t solid separately and you have to buy the hole assembly new, the lock says nearly 2kg in weight.
Yes Chippie mate.. All FB groups.. absolutely nothing..Have you tried phoning some “scrapyards” dismantlers to see if they have any e89 that they are stripping?
Yeah i saw it.. But when you zoom in the wiring has been messed with, so i'd probably be in same situation.. Apparently its a major fault with the wiring in the left side rotting or breakingI just had a look on eBay, there’s the full assembly listed, but there not cheap £325
You could make them an offer?
