BMW z4 e89 2012 sdrive28i
Aharrison0317
New member
 Texas
I have a bmw z4 that has a convertible top issue. I’ve replaced all my bad switches and no longer have any codes , I clicked the button for the convertible top issue close and my rear windows wend down but nothing else happened. The latches inside the cab are locked and the main windows do not work nor does the latch for the trunk. I found that when I click the button for it to open there is a clicking sound coming from the fuse box inside the cab of the car no clicking from the relays. Have tried to verify that the motor works properly by manually attaching 12v and a ground and verified that it works properly, I checked the voltage coming from my (pink/salmon) relay to the motor and I noticed that I get nothing when I click the button open or close. Do you have any advice on what it may be ? The boot moves freely and can be picked up by hand and so can the roof piece with the back glass verified that the screws are in the correct position on my pump making sure it isn’t bleeding out air , I’m just at a point where I don’t know any more.
If the front windows don’t go down then the roof won’t move, so I think that’s the 1st place to look, have you checked the fuse box to see if any fuse’s have blown?
