6. Now remove the weather stripping that attaches the top to the car. Only remove it from around the car body, NOT from the top itself. Don't try to remove it from the top or you will be buying a new top....
Part way removed....
Do you mean this? If so it's a simple case of pulling the roof seal off where it joins the car along the back at the bottom of the window.
