Hi All... I understand I probably wont get an answer to this but its worth a shot...
I have 2 OBDII Cables, one for NCS Expert (and works with BMW Scanner 1.4.0 Demo), and one for BMW Scanner 1.4.0. The problem I have is that when the NCS cable is fully plugged in, It can only read the DME ECU, none of other modules will read. I then found out by accident that when I move the cable a little, so that the rear most pins are almost unplugged, the cable will then read all modules (ASC, LCM, Airbags etc etc)!!
Now i've just tried my BMW Scanner 1.4.0 cable... Its doing the same thing, only reading the DME. I've tried moving the cable like I did the NCS one, however it doesn't seem to work.
Can anyone help? Am I missing something?
