Hi all...
Car went into garage for leaky headlamp washers and leaky boot on Monday...
The car is under the comprehensive BMW Insured Warranty.
They replaced a headlamp washer and charged me the £100 excess to do this, but wont fix the leaky boot... they say the warranty does not cover ANY water ingress, even if it isnt a normal boot seal that is the problem.
They said the leak is where the roof meets the rear bulkhead and it needs re-sealing (sounds like a sealant rather then an actual rubber seal). They would have charged me £660 just for labour for doing this job (taking the roof off)....
Firstly, does this sound right to anyone else with experience of the insured warranty? This is not a perishable item or wear & tear, this is some sealant on an internal joint, a joint that you cannot get to for normal maintanance or service. This seal would have been designed to never need replacing... so this is a design or build fault... surely my warranty should cover this?
can anyone with experience of these BMW insured warranty clarify this point for me???
Also, if not, I need to get this done at an independant... Anyone know of a good 1 in or around Manchester area that you would trust to take your roof off??
