I have purchased both the above products. I am not sure about the amount of impregnating agent to use. It is a 250 ml container and i was wondering if you use the whole bottle for one treatment or would half that amount be sufficient. Thanks in advance.
If this is the BMW soft top cleaner and conditioner you are talking about, I used about a third to half the container for the first application. Following the instruction to the letter will make this work really well. I use it.
There should be instructions on the back, just peel off one side of the label. It's something like 3 or 4 cap fulls to 1 litre of water, should be plenty for a few more uses.
Make sure you don't get it on the body work though, someone on here suggested old bed sheets/towels around the windows I wish I'd done that when I applied it A few car washes later though and the residues all gone
The BMW top sealant is best in my books, I also used 1/2 the bottle with the proper water mix . You get great beading and top is protected!
I would not use the whole bottle in one application-, again do 2 applications, then put the car in the sun or garage to dry
I finally got round to doing my roof yesterday. The cleaner worked a treat and was easy to apply and use. I used half of the 250ml bottle of impreganating fluid and found I had more than enough. I could have used half as much and therefore a bottle would do four applications. I did not mask of windows or anything but when I was finished I washed the car body and then polished it with Autoglym Super Resin. All the residue was removed after this. The car will be one year old in October so I treated the seats to Autoglym leather care and was impressed with the results.
