BMW Bluetooth phone connection quiet
MartynFrancis
 Norwich
So, my car has th Bluetooth integration for phone calls. However I have an issue, it too damn quiet. I have an iPhone 6s and the volume is up on that. Ive upped the volume in the car using the mfsw yet it seems too quiet. The other end can hear me fine, but I can hear them at all? Is there anyway to boost/increase it at all?
Check settings - sounds- lock sounds. Make sure it's set to off. :thumbsup:
If still not working, try hard restarting the phone, press the home button and the off button at the same time and hold until you see the apple logo. Don't worry, it won't erase the phone, it just clears the cache and can clear bugs in the IOS. :thumbsup: :thumbsup:
You can increase it slightly through the "secret menu"
- Switch the ignition to "on" (as long as there's power to the radio, it can be at any position)
- Switch the radio on (if it's on already, switch it off then on)
- Immediately press and hold the [SEL] button - keep depressed for around 8 seconds until you see the Service menu. It will show a Serial Number.
- Move through the menu options using the station search keys [<] and [>]
- When you see GAL, set to the highest level (6) by pressing button [6]. This is the speed sensitive volume setting, 1 being lowest and 6 being highest.
- Switch the radio off to exit the services menu
Other things: increase bluetooth volume (only available on the iPhone when the bluetooth call is in progress). This is different from the usual volume setting.
