Standard 'Offset' for the Zed is 47 front and 50 rear so these should be Ok. Dave the wheel nut on this forum is the expert on these matters - but the offset is the distance from its hub mounting surface to the centerline of the wheel - so your wheel will stick out 2mm further at the front and 2mm further at the rear. Link below may help:
