Bluetooth Call
Vonlipvig
 West Devon
Discovered today that when you are on a call via the in car bluetooth, if you pull over, turn the engine off and take the key out, the bluetooth remains on until the call ends. Someone at BMW probably thought they were being helpful but I wanted to get out of the car while not having to mess around. Might be of use to someone one day :)
This is the ying and yang that means under certain circumstances the Bluetooth connection stays alive resulting in a flat battery if the car is not locked..
