Blue tooth not working after intravee & satnav retrofit
jamiecarpenter
 Coventry
I've now installed my satnav and intravee both seem to be working fine. However I stuipdly deleted my phone from the bluetooth for the car. So I then tried to resink it with the car by having the phone on blue tooth holding down the speaker button for 3 seconds then turning the key to position one and holding it for a further 3 seconds then releasing it. However I cant get it to sink. Nothing happens just the usual menu screen for satnav functions. Due to never doing this before with the satnav installed, I dont no what should happen. Also I have had the phone working with the satnav before I deleted the connection off my phone by mistake, so I know it works. I've also double checked all the wiring so I know it's not that. Anyone any ideas? :headbang:
I had this with mine, I found the only way to start the sync process was not to stop at p1 but to start the engine. Also I believe you need to have the drivers door open when you do this?
Good luck
Saxon
What cured mine, was to switch off the bluetooth on the phone (or alternativly switch the phone off), then back on again and re sync, worked straight away.
Russell
