T thespannerman Member Oldbury, West Midlands Jun 25, 2021 #1 If I change the roof pump and motor, does anything have to be bled or do you just refill the oil and off it goes ok. Al
BumpyZ4 Active member New Orleans, LA USA Jun 25, 2021 #2 The system is self bleeding. Fill it up and run the roof up and down a few times. Make sure you keep an eye on the fluid level and add as needed.
enuff_zed Lifer Attleborough, Norfolk Jun 25, 2021 #4 Well I'm sorry but having read the title and seen where the pump is located I would have replied that bleeding was more than likely, yes.
bigwinn Lifer Lincoln UK Site Supporter Jun 25, 2021 #5 Was going to comment the only thing that bled when I moved the roof motor was my knuckles But yeah- it’s self bleeding
T thespannerman Member Oldbury, West Midlands Jun 26, 2021 #6 Haha. My pump is already located in the boot, so a much easier swap out ( hopefully) Al
