Bleed procedure help
mwhitely5
New member
Need help with the bleeding procedure
Replaced all my cooling parts this weekend except the radiator. Did water pump, hoses, thermostat, expansion tank etc.
Doing the bleeding procedure now. I have the bleeder screw off and expansion tank cap off. Filled with 50/50 mix until coolant just barely ran over the top of the radiator. Turned the engine on and put the heat on full blast
After about 10 minutes there is still coolant literally spewing out of my bleeder screw. Probably a half gallon has come out. What am I doing wrong?
Close it!
You are only supposed to have it open to let air out
If the vents are blowing hot in the car all should be well
bigwinn said:
Close it!
Did the procedure again with the key in position 2, looks like it worked much better and temp holding steady with everything closed off and engine running. Appreciate the help!
Good stuff
Make sure it’s not overfilled- that can lead to over pressure
