Not sure if this is in the right section so mods please feel free to move it if necessary.
Iv got an 07 reg coupe with the standard business set up, what I want to do to get a bit more bass into the car is build a custom enclosure in the boot and run a slimline 10” sub with a small amp tucked away somewhere.
All straight forward so far but what I need help with is:- what is the easiest way to get to the speakers behind the head rests as I am intending to tap the signal from these and run it to the speaker level inputs on the amp? Is there any way i can get to these speakers from the boot to make runing the cable easy?
There is a cardboard type panel which looks as if it should come away from the back of the boot but im a bit reluctant to go pulling off bits of trim without knowing if im actually in the right area.
Has anyone done something similar or got any pictures of the boot without bits of the trim installed so I can gauge what lives where, also does anybody know if the signal sent to the rear head rest speaker is full range?
Any help would be appreciated so I can get started on this asap, the sub iv got only requires 17litre box and a 85mm mounting depth so hopefully should be quite a tidy install.
