BBS LMR reps
Stug
Wiltshire
http://www.z4-forum.com/forum/viewtopic.php?f=7&t=36058&start=15&hilit=heads+up+wheels
Ok, i have collected these wheels and they are very nice, but maybe a little too shiney? they have a massive stepped rim that is mirror polished, I find it a little too 'blingy', so my question is do i flat down the rim and destroy the shiney finish then re- lacquer them, if so any ideas on how? i am thinking wet and dry around 600 grit or maybe using my dremel? :?
Yep. just too 'gypsy caravan' for me lol. they look almost chrome. I want them to have a more 'brushed' alloy finish.
I would suggest using a mobile wheel refurbisher if you want to get a finish that would last and not look odd.
Guess that could be costly so you could just sell them on and get a set you like...
Sent from my iPad using Tapatalk HD
If its polished by sanding it you run the risk of letting water in lifting the lacquer off which will ruin them.
Personally i would take them to a wheel shop... Cant be more then £30 each to paint the lip only.
Thanks fellas. i think i will try sanding them back the re lacquer them to seal the alloy from the elements. Other than the super shiney finish i love the look of the wheels. i guess if it all goes wrong i can always get them professionally sorted.
Wish me luck I am going in.... :wink:
