Hello everyone,
I know there are a ton of posts out there on battery issues and I am seeing many different opinions so I am trying to clear things up. Admittedly, I am dumb to BMW as this is my first one (USA 2006 Z4). The car has sat for 3 weeks and it is dead dead! When I first bought the car in the fall I had the battery tested (just at an auto parts store) and they said it was still good.
I am reading to jump it from the front and not the back battery which not knowing, I did jump it a while back from the rear with no issues. Today I tried the same (not knowing BMW made terminals under the hood) and had no luck and needed to get to work so I jumped in my other vehicle.
Here are my questions:
- Hooking it up to the front, should it start right away off a jump or leave it hooked up at least 15 minutes before trying? I don't have a dedicated battery charger so if I get it to start I will just keep the car running to charge it.
- If it doesn't start right away, can I just keep the host vehicle running while it is connected to the front terminals to keep it charging?
- If I do need a new battery, what battery should I buy and what is the process of changing it myself without messing anything up? A proper idiots guide to changing a BMW battery would be greatly appreciated!
