Battery not charged - Black dot
azazelus
Hi Guys
I havent started the car for a while. It seems the battery indicates the black dot - not sufficient charge and the car is not starting.
How should i charge the battery for z4? Do i need a special charger?
3.7A slow charge will be ok for this battery? Take it out of the car and leave it overnight?
Please advice.
Try charging it first take it out or at least disconnect the cables ,in my experience dead batteries don't respond well to charging especially when they are old .but its worth a try
You won't lose any radio codes, it'll work fine when you reconnect the battery. You will need to re-set the clock and the one-touch function for the windows, that's it.
If you've got the original battery in your car you'd probably be as well getting a new one. The build month/year of the battery is stamped on the top or side of one of the terminals I think.
You know what, I have no idea. But I'd suspect at least weeks or months ?
